Introdução
This guide will illustrate how to change your "DJI Mavic 2 Pro" battery. If the device is experiencing power-related issues, it may be caused by problems with the battery. Please ensure your device is powered off and disconnected from any external power source before beginning. The process is simple and should not take much time. There will be no tools needed.
O que você precisa
Press the buttons on the sides of the drone and pull the battery upwards from the drone to remove it.
Set aside and charge dead battery.
If all directions are followed, you have successfully replaced your DJI Mavic 2 Pro battery.
Uma outra pessoa concluiu este guia.
