Ir para o conteúdo principal
DBPOWER T20 Speaker Replacement
O que você precisa
  1. DBPOWER T20 Speaker Replacement, DBPOWER T20 Disassembly: passo 1, imagem 1 %32
    • Flip the device and lay flat.
  2. DBPOWER T20 Speaker Replacement: passo 2, imagem 1 %32
    • Remove the four (9 mm) screws with a PH2 screwdriver.
    • Remove the two (7 mm) located with a PH2 screwdriver.
  3. DBPOWER T20 Speaker Replacement: passo 3, imagem 1 %32 DBPOWER T20 Speaker Replacement: passo 3, imagem 2 %32 DBPOWER T20 Speaker Replacement: passo 3, imagem 3 %32
    • Flip the device over and pry the top off with a plastic opening tool.
  4. DBPOWER T20 Speaker Replacement: passo 4, imagem 1 %32
    • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
  5. DBPOWER T20 Speaker Replacement: passo 5, imagem 1 %32 DBPOWER T20 Speaker Replacement: passo 5, imagem 2 %32
    • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
  6. DBPOWER T20 Speaker Replacement: passo 6, imagem 1 %32 DBPOWER T20 Speaker Replacement: passo 6, imagem 2 %32 DBPOWER T20 Speaker Replacement: passo 6, imagem 3 %32
    • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
    • the black cable requires more force to remove than the other cables.
  7. DBPOWER T20 Speaker Replacement: passo 7, imagem 1 %32 DBPOWER T20 Speaker Replacement: passo 7, imagem 2 %32
    • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
  8. DBPOWER T20 Speaker Replacement: passo 8, imagem 1 %32
    • Raise motherboard by lifting sideways and then up to avoid the ports.
  9. DBPOWER T20 Speaker Replacement: passo 9, imagem 1 %32 DBPOWER T20 Speaker Replacement: passo 9, imagem 2 %32
    • Remove wires attaching the piezoelectric speakers to the motherboard.
  10. DBPOWER T20 Speaker Replacement: passo 10, imagem 1 %32 DBPOWER T20 Speaker Replacement: passo 10, imagem 2 %32
    • Remove the five screws securing the black plastic cover with a J0 screwdriver.
    • Lift up and out to remove.
  11. DBPOWER T20 Speaker Replacement, Speaker: passo 11, imagem 1 %32 DBPOWER T20 Speaker Replacement, Speaker: passo 11, imagem 2 %32
    • Remove the two (3 mm) screws connecting the bracket down and pull out the reflector, using a J0 Philips Head Screwdriver.
  12. DBPOWER T20 Speaker Replacement: passo 12, imagem 1 %32 DBPOWER T20 Speaker Replacement: passo 12, imagem 2 %32 DBPOWER T20 Speaker Replacement: passo 12, imagem 3 %32
    • Slide the mirror straight up to remove.
  13. DBPOWER T20 Speaker Replacement: passo 13, imagem 1 %32 DBPOWER T20 Speaker Replacement: passo 13, imagem 2 %32 DBPOWER T20 Speaker Replacement: passo 13, imagem 3 %32
    • Slide out the power source and disconnect its cables from the power jack and the light.
  14. DBPOWER T20 Speaker Replacement: passo 14, imagem 1 %32 DBPOWER T20 Speaker Replacement: passo 14, imagem 2 %32 DBPOWER T20 Speaker Replacement: passo 14, imagem 3 %32
    • Remove the screws holding down the first speaker with a J0 screwdriver.
    • Remove the screws holding down the second speaker down.
Conclusão
Ryan Goldin
Membro desde: 02/15/18
245 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S16-G2, Boczar Spring 2018 Membro de USF Tampa, Team S16-G2, Boczar Spring 2018
USFT-BOCZAR-S18S16G2
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 421
