Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the four (9 mm) screws with a PH2 screwdriver.
Remove the two (7 mm) located with a PH2 screwdriver.
Flip the device over and pry the top off with a plastic opening tool.
Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
Raise motherboard by lifting sideways and then up to avoid the ports.
Remove wires attaching the piezoelectric speakers to the motherboard.
Remove the five screws securing the black plastic cover with a J0 screwdriver.
Lift up and out to remove.
Detach the keystone adjuster from the lens housing.
Remove the rubber foot and warranty sticker found underneath the device.
Remove the two screws on the bottom of the device with a J0 screwdriver.
Remove the focus-adjustment ring from the lens housing.
3 outras pessoas executaram este guia.
3 comentários
I need to know the same
Trying to put my lens back how to install
