Ir para o conteúdo principal
DBPOWER T20 Lens Replacement
O que você precisa
  1. DBPOWER T20 Lens Replacement, DBPOWER T20 Disassembly: passo 1, imagem 1 %32
    • Flip the device and lay flat.
  2. DBPOWER T20 Lens Replacement: passo 2, imagem 1 %32
    • Remove the four (9 mm) screws with a PH2 screwdriver.
    • Remove the two (7 mm) located with a PH2 screwdriver.
  3. DBPOWER T20 Lens Replacement: passo 3, imagem 1 %32 DBPOWER T20 Lens Replacement: passo 3, imagem 2 %32 DBPOWER T20 Lens Replacement: passo 3, imagem 3 %32
    • Flip the device over and pry the top off with a plastic opening tool.
  4. DBPOWER T20 Lens Replacement: passo 4, imagem 1 %32
    • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
    which end of cable?
    Ki Ko - Responder
    looks hard and tightly connected. put an arrow
    Ki Ko - Responder
  5. DBPOWER T20 Lens Replacement: passo 5, imagem 1 %32 DBPOWER T20 Lens Replacement: passo 5, imagem 2 %32
    • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
    one of the screws have been stripped, I’ve tried the rubber band and the glue trick, it didn’t work. What do I do to remove it? please respond
    arman waggoner - Responder
  6. DBPOWER T20 Lens Replacement: passo 6, imagem 1 %32 DBPOWER T20 Lens Replacement: passo 6, imagem 2 %32 DBPOWER T20 Lens Replacement: passo 6, imagem 3 %32
    • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
    • the black cable requires more force to remove than the other cables.
  7. DBPOWER T20 Lens Replacement: passo 7, imagem 1 %32 DBPOWER T20 Lens Replacement: passo 7, imagem 2 %32
    • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
    very well explained, let's also tell the other one how it goes
    Ki Ko - Responder
  8. DBPOWER T20 Lens Replacement: passo 8, imagem 1 %32
    • Raise motherboard by lifting sideways and then up to avoid the ports.
    hard, very hard, I have a feeling that something will break
    Ki Ko - Responder
  9. DBPOWER T20 Lens Replacement: passo 9, imagem 1 %32 DBPOWER T20 Lens Replacement: passo 9, imagem 2 %32
    • Remove wires attaching the piezoelectric speakers to the motherboard.
  10. DBPOWER T20 Lens Replacement: passo 10, imagem 1 %32 DBPOWER T20 Lens Replacement: passo 10, imagem 2 %32
    • Remove the five screws securing the black plastic cover with a J0 screwdriver.
    • Lift up and out to remove.
  11. DBPOWER T20 Lens Replacement, Lens: passo 11, imagem 1 %32
    • The lamp does not need to be removed for this step to be preformed.
  12. DBPOWER T20 Lens Replacement: passo 12, imagem 1 %32
    • Detach the keystone adjuster from the lens housing.
    • Lens is on a hinge so it should lift off easily, if it doesn't, adjust by swaying it forward or backward.
  13. DBPOWER T20 Lens Replacement: passo 13, imagem 1 %32
    • Remove the rubber foot and warranty sticker found underneath the device.
  14. DBPOWER T20 Lens Replacement: passo 14, imagem 1 %32 DBPOWER T20 Lens Replacement: passo 14, imagem 2 %32
    • Remove the two screws on the bottom of the device with a J0 screwdriver.
  15. DBPOWER T20 Lens Replacement: passo 15, imagem 1 %32
    • Remove the focus-adjustment ring from the lens housing.
    How do we replace the lens? I replaced my lens and it hasnt been clear ever since.. Too much blurr
    Eluby Dana Wingolo - Responder
Conclusão
3 outras pessoas executaram este guia.
Andrea Espinosa
Membro desde: 02/15/18
506 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S16-G2, Boczar Spring 2018 Membro de USF Tampa, Team S16-G2, Boczar Spring 2018
USFT-BOCZAR-S18S16G2
Membros da 5
Autoria de 5 guias
3 comentários
How does the lens parts go together?
Lay - Responder
I need to know the same
Tremaine Mullins - Responder
Trying to put my lens back how to install
David Williams - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 32
Duração total: 2,288
