Introdução
Taking out the fan is quick and easy. When removing the fan it is okay to use some force as it's not delicate.
O que você precisa
Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
one of the screws have been stripped, I’ve tried the rubber band and the glue trick, it didn’t work. What do I do to remove it? please respond
7 outras pessoas executaram este guia.
2 comentários
Any idea of the specifications of the fan? 12v, 24v? I want to change it for another more quiet… but not sure about its voltage. It is 50x50x20mm right? Thanks!
Hola! También querria sustituirlo por otro más silencioso. ¿Alguna idea de sus especificaciones?
