Ir para o conteúdo principal
DBPOWER T20 Fan Replacement
O que você precisa
  1. DBPOWER T20 Fan Replacement, DBPOWER T20 Disassembly: passo 1, imagem 1 %32
    • Flip the device and lay flat.
  2. DBPOWER T20 Fan Replacement: passo 2, imagem 1 %32
    • Remove the four (9 mm) screws with a PH2 screwdriver.
    • Remove the two (7 mm) located with a PH2 screwdriver.
  3. DBPOWER T20 Fan Replacement: passo 3, imagem 1 %32 DBPOWER T20 Fan Replacement: passo 3, imagem 2 %32 DBPOWER T20 Fan Replacement: passo 3, imagem 3 %32
    • Flip the device over and pry the top off with a plastic opening tool.
  4. DBPOWER T20 Fan Replacement: passo 4, imagem 1 %32
    • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
    which end of cable?
    Ki Ko - Responder
    looks hard and tightly connected. put an arrow
    Ki Ko - Responder
  5. DBPOWER T20 Fan Replacement: passo 5, imagem 1 %32 DBPOWER T20 Fan Replacement: passo 5, imagem 2 %32
    • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
    one of the screws have been stripped, I’ve tried the rubber band and the glue trick, it didn’t work. What do I do to remove it? please respond
    arman waggoner - Responder
  6. DBPOWER T20 Fan Replacement: passo 6, imagem 1 %32 DBPOWER T20 Fan Replacement: passo 6, imagem 2 %32 DBPOWER T20 Fan Replacement: passo 6, imagem 3 %32
    • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
    • the black cable requires more force to remove than the other cables.
  7. DBPOWER T20 Fan Replacement: passo 7, imagem 1 %32 DBPOWER T20 Fan Replacement: passo 7, imagem 2 %32
    • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
    very well explained, let's also tell the other one how it goes
    Ki Ko - Responder
  8. DBPOWER T20 Fan Replacement: passo 8, imagem 1 %32
    • Raise motherboard by lifting sideways and then up to avoid the ports.
    hard, very hard, I have a feeling that something will break
    Ki Ko - Responder
  9. DBPOWER T20 Fan Replacement: passo 9, imagem 1 %32 DBPOWER T20 Fan Replacement: passo 9, imagem 2 %32
    • Remove wires attaching the piezoelectric speakers to the motherboard.
  10. DBPOWER T20 Fan Replacement: passo 10, imagem 1 %32 DBPOWER T20 Fan Replacement: passo 10, imagem 2 %32
    • Remove the five screws securing the black plastic cover with a J0 screwdriver.
    • Lift up and out to remove.
  11. DBPOWER T20 Fan Replacement, Fan: passo 11, imagem 1 %32 DBPOWER T20 Fan Replacement, Fan: passo 11, imagem 2 %32
    • Pull the fan up and out of the housing.
    • In this image the lamp and power input have been removed to increase visibility, you do not have to remove these to remove the fan.
Conclusão
7 outras pessoas executaram este guia.
Equipe
USF Tampa, Team S16-G2, Boczar Spring 2018 Membro de USF Tampa, Team S16-G2, Boczar Spring 2018
USFT-BOCZAR-S18S16G2
Membros da 5
Autoria de 5 guias
2 comentários
Any idea of the specifications of the fan? 12v, 24v? I want to change it for another more quiet… but not sure about its voltage. It is 50x50x20mm right? Thanks!
Agustín Castiñeira Fernández - Responder
Hola! También querria sustituirlo por otro más silencioso. ¿Alguna idea de sus especificaciones?
Joan Abrines - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 1,114
