Introdução
The power supply circuit controls the flow of electricity into the projector. If the projector is not turning on, the Power Supply Circuit may need to be replaced.
This guide can also be used to allow access to the power supply switch.
O que você precisa
Place the projector upside down to access the screws on the bottom.
Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
Remove the three 6mm PH2 phillips head screws.
Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
Remove the two 9mm PH2 phillips head screws.
Lift the mirror behind the power supply circuit out to gain access to the circuit board.
Uma outra pessoa concluiu este guia.
