Ir para o conteúdo principal
DBPOWER RD-810 Imager Replacement
O que você precisa
  1. DBPOWER RD-810 Imager Replacement, Top Cover: passo 1, imagem 1 %32 DBPOWER RD-810 Imager Replacement, Top Cover: passo 1, imagem 2 %32
    • Make sure the projector is unplugged before starting
    • Place the projector upside down to access the screws on the bottom.
    • Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
  2. DBPOWER RD-810 Imager Replacement: passo 2, imagem 1 %32
    • Flip the projector over and then remove the cover by lifting it up.
  3. DBPOWER RD-810 Imager Replacement, Motherboard and LED Bulb: passo 3, imagem 1 %32 DBPOWER RD-810 Imager Replacement, Motherboard and LED Bulb: passo 3, imagem 2 %32 DBPOWER RD-810 Imager Replacement, Motherboard and LED Bulb: passo 3, imagem 3 %32
    • Remove the three 6mm PH2 phillips head screws.
    • Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
  4. DBPOWER RD-810 Imager Replacement: passo 4, imagem 1 %32 DBPOWER RD-810 Imager Replacement: passo 4, imagem 2 %32 DBPOWER RD-810 Imager Replacement: passo 4, imagem 3 %32
    • Disconnect the three wire connectors. Grasp both sides of the connector and pull apart.
    • Keep the connector parallel to the mother board to avoid breaking the solder connection.
    • Lift the motherboard up and place it out of the way.
  5. DBPOWER RD-810 Imager Replacement: passo 5, imagem 1 %32 DBPOWER RD-810 Imager Replacement: passo 5, imagem 2 %32 DBPOWER RD-810 Imager Replacement: passo 5, imagem 3 %32
    • Remove the five 7mm PH2 phillips head screws on the black plate and lift the plate out.
    • Lift the aluminum heat sink up to remove it from the projector.
    • The motherboard is already removed in this step.
  6. DBPOWER RD-810 Imager Replacement, Imager: passo 6, imagem 1 %32
    • Lift the imager straight up to remove it from the projector.
Conclusão
John Russell
Membro desde: 02/14/18
914 Reputação
Autoria de 9 guias
Equipe
USF Tampa, Team S5-G3, Eyestone Spring 2018 Membro de USF Tampa, Team S5-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S5G3
Membros da 3
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 14
Duração total: 510
