Introdução
The fan removes warm air from the inside of the projector. If the fan is not working correctly, the projector could overheat and damage could occur.
This guide can also help to keep the fan clean from dust and dirt to prevent overheating.
O que você precisa
Place the projector upside down to access the screws on the bottom.
Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
Remove the three 6mm PH2 phillips head screws.
Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
Uma outra pessoa concluiu este guia.
2 comentários
Wich cooler does fit ? I just bought the Projector and want to change the Fan because it is too loud
