Ir para o conteúdo principal
D5 Pump Impeller Replacement
O que você precisa
  1. D5 Pump Impeller Replacement, Impeller: passo 1, imagem 1 %32 D5 Pump Impeller Replacement, Impeller: passo 1, imagem 2 %32
    • Drain your water-cooling loop and disconnect any fittings.
    • Grasp the retaining ring and twist counter-clockwise to free the pump from the housing.
  2. D5 Pump Impeller Replacement: passo 2, imagem 1 %32 D5 Pump Impeller Replacement: passo 2, imagem 2 %32
    • After the pump has been removed, grasp the impeller and rotate it. If it has any resistance, a replacement is necessary.
    • Firmly hold the impeller and pull. It will take some force to remove.
  3. D5 Pump Impeller Replacement: passo 3, imagem 1 %32 D5 Pump Impeller Replacement: passo 3, imagem 2 %32
    • After the impeller has been removed, use a cloth to clean any debris.
    • Use a cotton swab to clean any gunk or residue from tight spaces.
    • Not cleaning the pump before installing a new impeller can cause it to fail.
  4. D5 Pump Impeller Replacement: passo 4, imagem 1 %32
    • Place the new impeller into the pump body by dropping it in. This doesn't require any force.
  5. D5 Pump Impeller Replacement: passo 5, imagem 1 %32
    • Manually test your impeller by pressing down and rotating it.
    • If there is any resistance, turning it on could damage the new impeller. Ensure that it was thoroughly cleaned.
  6. D5 Pump Impeller Replacement: passo 6, imagem 1 %32
    • Visually inspect your impeller. It should be parallel to the pump.
    • If the impeller is lopsided, remove it and ensure that there is no debris blocking the installation.
Conclusão
To reassemble your device, follow the first step in reverse.
James Gibson
Membro desde: 10/28/20
133 Reputação
Autoria de 1 guia
Equipe
Texas Tech, Team S14-G3, Cowan Fall 2020 Membro de Texas Tech, Team S14-G3, Cowan Fall 2020
TTU-COWAN-F20S14G3
1 Membro
1 Guia de autoria
4 comentários
Wow, that was useless. I mean it’s pretty obvious and straightforward process. If you are capable of assembling the loop, you are more than capable of replacing the impeller without any guide. The question is where can one find a new impeller, but ofc this useless guide won’t tell you.
Angry Beaver - Responder
Have not found one place selling impellers other then AliExpress but after shipping and everything you might as well buy a whole pump unit and have a warranty.
JMan31337 - Responder
What angry beaver said.
Mindbulletz - Responder
Sam Weiler - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 46
Duração total: 3,354
