Ir para o conteúdo principal
D-link PowerLine Hard Reset
O que você precisa
  1. D-link PowerLine Hard Reset, D-link PowerLine Hard Reset: passo 1, imagem 1 %32
    • (With router unpluged, and no ethernet cable attched) Turn the router on (push in the power button on the side) remember it's not plugged into the wall yet.
  2. D-link PowerLine Hard Reset: passo 2, imagem 1 %32
    • Take a pin or micro screwdriver and push in and hold the reset button.
    • Still holding the reset button plug the router into a power outlet.
    • Keep holding down the reset button for at least 15 seconds.
    • If you have the same luck I did your green lights on the side will start to cycle and light up.
    • Now you can go back to your quick install guide that came with the router and set it up again.
Conclusão
hope it works for you
4 outras pessoas executaram este guia.
alan
Membro desde: 08/23/13
1 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 5,933
