Ir para o conteúdo principal
D-Link HD Wi-Fi Camera Microphone Replacement
O que você precisa
  1. D-Link HD Wi-Fi Camera Microphone Replacement, Motherboard: passo 1, imagem 1 %32
    • Place the camera upwards between your thumb and first finger.
    • Tilt the camera to the best position and loosen the captive linings using a plastic opening tool.
    • Slide the top cover outwards to separate the upper section from the lower lid using the plastic opening tool.
  2. D-Link HD Wi-Fi Camera Microphone Replacement: passo 2, imagem 1 %32 D-Link HD Wi-Fi Camera Microphone Replacement: passo 2, imagem 2 %32
    • Remove the 6.0mm Phillips #00 screws that secure the back cover to the inner frame.
    • Lift the rear lid upwards using your fingers and separate it from the internal components and motherboard.
  3. D-Link HD Wi-Fi Camera Microphone Replacement: passo 3, imagem 1 %32 D-Link HD Wi-Fi Camera Microphone Replacement: passo 3, imagem 2 %32
    • Unscrew the motherboard from the frame. There are 3 Phillips #00 5.0mm screws holding it in place.
    • Then (gently!) remove the motherboard and the lens with your fingers.
  4. D-Link HD Wi-Fi Camera Microphone Replacement, Microphone: passo 4, imagem 1 %32
    • To remove the front cover, place index finger in the center and pull away from the frame. This may take a little effort, but should not require an opening tool.
  5. D-Link HD Wi-Fi Camera Microphone Replacement: passo 5, imagem 1 %32 D-Link HD Wi-Fi Camera Microphone Replacement: passo 5, imagem 2 %32
    • After the cover is removed, unscrew the two Phillips #00 5.0mm screws. Then the board should slide right out.
Conclusão
Morgen Jaques
Membro desde: 09/28/17
557 Reputação
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 533
