Ir para o conteúdo principal
D-Link HD Wi-Fi Camera Camera Lens Replacement
O que você precisa
  1. D-Link HD Wi-Fi Camera Camera Lens Replacement, Motherboard: passo 1, imagem 1 %32
    • Place the camera upwards between your thumb and first finger.
    • Tilt the camera to the best position and loosen the captive linings using a plastic opening tool.
    • Slide the top cover outwards to separate the upper section from the lower lid using the plastic opening tool.
  2. D-Link HD Wi-Fi Camera Camera Lens Replacement: passo 2, imagem 1 %32 D-Link HD Wi-Fi Camera Camera Lens Replacement: passo 2, imagem 2 %32
    • Remove the 6.0mm Phillips #00 screws that secure the back cover to the inner frame.
    • Lift the rear lid upwards using your fingers and separate it from the internal components and motherboard.
  3. D-Link HD Wi-Fi Camera Camera Lens Replacement: passo 3, imagem 1 %32 D-Link HD Wi-Fi Camera Camera Lens Replacement: passo 3, imagem 2 %32
    • Unscrew the motherboard from the frame. There are 3 Phillips #00 5.0mm screws holding it in place.
    • Then (gently!) remove the motherboard and the lens with your fingers.
  4. D-Link HD Wi-Fi Camera Camera Lens Replacement, Camera Lens: passo 4, imagem 1 %32 D-Link HD Wi-Fi Camera Camera Lens Replacement, Camera Lens: passo 4, imagem 2 %32
    • Make sure your hands are dry and you are working in a dry area. To prevent damage, do not touch the lens.
    • There are two Phillips #00 6.0mm screws keeping the camera in place. Remove the screws first.
    • Gently unplug the camera from the motherboard, and remove the camera.
Conclusão
Morgen Jaques
Membro desde: 09/28/17
533 Reputação
Autoria de 5 guias
Um comentário
How do I get hold of a replacement lens? Can’t seem to find anyone selling them. Need one for a DCS-2670L
Paul Williams - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 1,092
