Ir para o conteúdo principal
D-Link EBR-2310 Motherboard Replacement
O que você precisa
  1. D-Link EBR-2310 Motherboard Replacement, Remove Plastic Screw Coverings: passo 1, imagem 1 %32
    • Begin by placing the wired router face down.
    • Locate the two black plastic screw coverings at the top of the device and remove them with your fingers.
    • The two bottom plastic screw coverings do not need to be taken off.
  2. D-Link EBR-2310 Motherboard Replacement, Remove Screws: passo 2, imagem 1 %32
    • Using a Phillips #2 screwdriver, remove the two top screws.
  3. D-Link EBR-2310 Motherboard Replacement, Pry Open The Router: passo 3, imagem 1 %32
    • Use a plastic opening tool between the edges of the router and gently pry the device apart.
    • Release the clips as you work your way around the device to avoid breaking them.
    • Separate the front and back case of the router.
  4. D-Link EBR-2310 Motherboard Replacement, Remove Silver Casing: passo 4, imagem 1 %32 D-Link EBR-2310 Motherboard Replacement, Remove Silver Casing: passo 4, imagem 2 %32
    • Once you have removed the top black case of the router, remove the silver casing surrounding the logic board.
    • It should easily snap out of place.
  5. D-Link EBR-2310 Motherboard Replacement, Remove Inner Bottom Screws: passo 5, imagem 1 %32 D-Link EBR-2310 Motherboard Replacement, Remove Inner Bottom Screws: passo 5, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove the two screws at the bottom of the motherboard.
  6. D-Link EBR-2310 Motherboard Replacement, Remove Bottom Case: passo 6, imagem 1 %32
    • Now that you have removed all screws and the surrounding silver casing, pop the logic board out from the bottom component of the router.
    • You have now removed the logic board from your device.
Conclusão
Uma outra pessoa concluiu este guia.
Jessica
Membro desde: 09/19/14
428 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 828
