Ir para o conteúdo principal
D-Link DCS-825L LED Light Cover Replacement
O que você precisa
  1. D-Link DCS-825L LED Light Cover Replacement, Accent Ring: passo 1, imagem 1 %32
    • Grasp the side of the accent ring. There is a notch that your thumb will be able to grab ahold of.
  2. D-Link DCS-825L LED Light Cover Replacement: passo 2, imagem 1 %32
    • Twist the accent ring until it pops off. You may need to use both hands if the accent ring is stuck.
  3. D-Link DCS-825L LED Light Cover Replacement: passo 3, imagem 1 %32
    • Replace your accent ring with whichever color you choose.
  4. D-Link DCS-825L LED Light Cover Replacement, Back Casing: passo 4, imagem 1 %32 D-Link DCS-825L LED Light Cover Replacement, Back Casing: passo 4, imagem 2 %32
    • Remove one Phillips #2 screw from each side of the camera lens.
  5. D-Link DCS-825L LED Light Cover Replacement: passo 5, imagem 1 %32 D-Link DCS-825L LED Light Cover Replacement: passo 5, imagem 2 %32 D-Link DCS-825L LED Light Cover Replacement: passo 5, imagem 3 %32
    • Pull the Wi-Fi Baby Camera open.
    • It should be easily done after the screws are removed.
  6. D-Link DCS-825L LED Light Cover Replacement: passo 6, imagem 1 %32 D-Link DCS-825L LED Light Cover Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Take your tweezers and gently pull the white tip out from its plug that is connected to a red and black twisted wire.
  7. D-Link DCS-825L LED Light Cover Replacement: passo 7, imagem 1 %32 D-Link DCS-825L LED Light Cover Replacement: passo 7, imagem 2 %32 D-Link DCS-825L LED Light Cover Replacement: passo 7, imagem 3 %32
    • Take your tweezers and gently pull the white tip that is on the end of the white wire (the antenna) out from its plug in.
  8. D-Link DCS-825L LED Light Cover Replacement, LED Light Cover: passo 8, imagem 1 %32
    • Grab the white cylinder with your thumb and index finger.
  9. D-Link DCS-825L LED Light Cover Replacement: passo 9, imagem 1 %32
    • Gently lift the cylinder up from its placement in your Wi-Fi Baby Camera.
  10. D-Link DCS-825L LED Light Cover Replacement: passo 10, imagem 1 %32
    • Remove the white cylinder completely to replace it.
Conclusão
Annalise Leclair
Membro desde: 10/09/18
97 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S1-G5, Leahy Fall 2018 Membro de USF Tampa, Team S1-G5, Leahy Fall 2018
USFT-LEAHY-F18S1G5
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 299
