Ir para o conteúdo principal
D-Link DCS-825L Back Casing Replacement
O que você precisa
  1. D-Link DCS-825L Back Casing Replacement, Accent Ring: passo 1, imagem 1 %32
    • Grasp the side of the accent ring. There is a notch that your thumb will be able to grab ahold of.
    Pergunte ao FixBot
    Comentar
  2. D-Link DCS-825L Back Casing Replacement: passo 2, imagem 1 %32
    • Twist the accent ring until it pops off. You may need to use both hands if the accent ring is stuck.
    Pergunte ao FixBot
    Comentar
  3. D-Link DCS-825L Back Casing Replacement: passo 3, imagem 1 %32
    • Replace your accent ring with whichever color you choose.
    Pergunte ao FixBot
    Comentar
  4. D-Link DCS-825L Back Casing Replacement, Back Casing: passo 4, imagem 1 %32 D-Link DCS-825L Back Casing Replacement, Back Casing: passo 4, imagem 2 %32
    • Remove one Phillips #2 screw from each side of the camera lens.
    Pergunte ao FixBot
    Comentar
  5. D-Link DCS-825L Back Casing Replacement: passo 5, imagem 1 %32 D-Link DCS-825L Back Casing Replacement: passo 5, imagem 2 %32 D-Link DCS-825L Back Casing Replacement: passo 5, imagem 3 %32
    • Pull the Wi-Fi Baby Camera open.
    • It should be easily done after the screws are removed.
    Pergunte ao FixBot
    Comentar
  6. D-Link DCS-825L Back Casing Replacement: passo 6, imagem 1 %32 D-Link DCS-825L Back Casing Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Take your tweezers and gently pull the white tip out from its plug that is connected to a red and black twisted wire.
    Pergunte ao FixBot
    Comentar
  7. D-Link DCS-825L Back Casing Replacement: passo 7, imagem 1 %32 D-Link DCS-825L Back Casing Replacement: passo 7, imagem 2 %32 D-Link DCS-825L Back Casing Replacement: passo 7, imagem 3 %32
    • Take your tweezers and gently pull the white tip that is on the end of the white wire (the antenna) out from its plug in.
    Pergunte ao FixBot
    Comentar
Conclusão
April Ulrich
Membro desde: 10/09/18
217 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S1-G5, Leahy Fall 2018 Membro de USF Tampa, Team S1-G5, Leahy Fall 2018
USFT-LEAHY-F18S1G5
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 38
Ao todo: 658
