Ir para o conteúdo principal
D-Link DCS-825L Antenna Replacement
O que você precisa
  1. D-Link DCS-825L Antenna Replacement, Accent Ring: passo 1, imagem 1 %32
    • Grasp the side of the accent ring. There is a notch that your thumb will be able to grab ahold of.
    Pergunte ao FixBot
    Comentar
  2. D-Link DCS-825L Antenna Replacement: passo 2, imagem 1 %32
    • Twist the accent ring until it pops off. You may need to use both hands if the accent ring is stuck.
    Pergunte ao FixBot
    Comentar
  3. D-Link DCS-825L Antenna Replacement: passo 3, imagem 1 %32
    • Replace your accent ring with whichever color you choose.
    Pergunte ao FixBot
    Comentar
  4. D-Link DCS-825L Antenna Replacement, Back Casing: passo 4, imagem 1 %32 D-Link DCS-825L Antenna Replacement, Back Casing: passo 4, imagem 2 %32
    • Remove one Phillips #2 screw from each side of the camera lens.
    Pergunte ao FixBot
    Comentar
  5. D-Link DCS-825L Antenna Replacement: passo 5, imagem 1 %32 D-Link DCS-825L Antenna Replacement: passo 5, imagem 2 %32 D-Link DCS-825L Antenna Replacement: passo 5, imagem 3 %32
    • Pull the Wi-Fi Baby Camera open.
    • It should be easily done after the screws are removed.
    Pergunte ao FixBot
    Comentar
  6. D-Link DCS-825L Antenna Replacement: passo 6, imagem 1 %32 D-Link DCS-825L Antenna Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Take your tweezers and gently pull the white tip out from its plug that is connected to a red and black twisted wire.
    Pergunte ao FixBot
    Comentar
  7. D-Link DCS-825L Antenna Replacement: passo 7, imagem 1 %32 D-Link DCS-825L Antenna Replacement: passo 7, imagem 2 %32 D-Link DCS-825L Antenna Replacement: passo 7, imagem 3 %32
    • Take your tweezers and gently pull the white tip that is on the end of the white wire (the antenna) out from its plug in.
    Pergunte ao FixBot
    Comentar
  8. D-Link DCS-825L Antenna Replacement, Antenna: passo 8, imagem 1 %32
    • Once you have the back casing removed from the other half of the device, it should look like this with the antenna poking out.
    Pergunte ao FixBot
    Comentar
  9. D-Link DCS-825L Antenna Replacement: passo 9, imagem 1 %32 D-Link DCS-825L Antenna Replacement: passo 9, imagem 2 %32 D-Link DCS-825L Antenna Replacement: passo 9, imagem 3 %32
    • There will be a light yellow rubber stopper that is holding the antenna in place.
    • With your tweezers, gently tug on the stopper to make it come out, or at least come loose.
    • If the stopper does not completely come out, use the round top of the antenna to push down on it.
    • You can do this simply by pulling the antenna as close to the back casing as possible, and then pushing down on it until the rubber stopper comes out completely.
    • After it has come out, it can either be taken off from the antenna and set aside, or it can be kept on.
    Pergunte ao FixBot
    Comentar
  10. D-Link DCS-825L Antenna Replacement: passo 10, imagem 1 %32 D-Link DCS-825L Antenna Replacement: passo 10, imagem 2 %32
    • Once the rubber stopper has been pushed out, you will now be able to easily pull the antenna out from the back casing.
    • After it has been removed, you are now able to replace the antenna of your Wi-Fi Baby Camera.
    Pergunte ao FixBot
    Comentar
Conclusão
Alexis Clopton
Membro desde: 10/09/18
97 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S1-G5, Leahy Fall 2018 Membro de USF Tampa, Team S1-G5, Leahy Fall 2018
USFT-LEAHY-F18S1G5
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 33
Ao todo: 865
