Ir para o conteúdo principal
D-Link DCS-5222L Speaker Replacement
O que você precisa
  1. D-Link DCS-5222L Speaker Replacement, Speaker: passo 1, imagem 1 %32 D-Link DCS-5222L Speaker Replacement, Speaker: passo 1, imagem 2 %32 D-Link DCS-5222L Speaker Replacement, Speaker: passo 1, imagem 3 %32
    • Remove the four rubber pieces to gain access to the screws.
    • Remove the four 7mm screws with a #1 Phillips screwdriver.
    • Remove the bottom of the camera body.
  2. D-Link DCS-5222L Speaker Replacement: passo 2, imagem 1 %32 D-Link DCS-5222L Speaker Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using safety tweezers, disconnect the 2-wire connector with the red and black leads located close to the ethernet and SD ports.
    • Disconnect the cables gently.
  3. D-Link DCS-5222L Speaker Replacement: passo 3, imagem 1 %32 D-Link DCS-5222L Speaker Replacement: passo 3, imagem 2 %32
    • The speaker is circular, black and silver in color with a red and black cord. It is easily removed from the upper body of the camera with your fingers or safety tweezers.
Conclusão
Jason Munyon
Membro desde: 10/30/18
268 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S2-G5, Peak Fall 2018 Membro de UMass Dartmouth, Team S2-G5, Peak Fall 2018
UMASSD-PEAK-F18S2G5
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 309
