Ir para o conteúdo principal
D-Link DCS-2630L Wi-Fi Camera Microphone Replacement
O que você precisa
  1. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement, Back casing: passo 1, imagem 1 %32
    • Remove the two 9.65 mm screws on the back cover using the Philips head PH00 screw driver.
  2. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 2, imagem 1 %32
    • Remove the back casing to expose the circuit board.
  3. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 3, imagem 1 %32
    • Detach the gray antenna wires by gently pulling on the side closest to the circuit board.
  4. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 4, imagem 1 %32
    • Detach the speaker wire by gently pulling on the side closest to the body of the camera.
  5. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement, Microphone: passo 5, imagem 1 %32
    • Remove the two 4.35 mm screws on the circuit board using the Philips head PH00 screw driver.
  6. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 6, imagem 1 %32 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 6, imagem 2 %32
    • Detach the white plug by gently pulling on the black wires.
  7. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 7, imagem 1 %32 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 7, imagem 2 %32
    • Remove the circuit board to expose the camera body.
    • At the same time, you will need to feed the wires through the circuit board and out the slot in the black plate under the circuit board.
  8. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 8, imagem 1 %32 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 8, imagem 2 %32
    • Gently pull on the grey wire to detach the microphone from the camera body.
  9. D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 9, imagem 1 %32 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 9, imagem 2 %32 D-Link DCS-2630L Wi-Fi Camera Microphone Replacement: passo 9, imagem 3 %32
    • Detach the microphone from the circuit board by gently pulling on the grey wire.
Conclusão
Equipe
IUPUI, Team S4-G2, Baechle Spring 2018 Membro de IUPUI, Team S4-G2, Baechle Spring 2018
IUPUI-BAECHLE-S18S4G2
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 377
