Introdução
This guide will show how to take apart a D-Link DCS 936L Wi-Fi security camera and remove the motherboard using an opening tool and a Philips 00 screwdriver. There are not many loose pieces making this a quick process as long as you're careful.
O que você precisa
Place the camera upwards between your thumb and first finger.
Tilt the camera to the best position and loosen the captive linings using a plastic opening tool.
Slide the top cover outwards to separate the upper section from the lower lid using the plastic opening tool.
Um comentário
Where can I get the replacement motherboard? Been trying to search online, but to no avail.
