Ir para o conteúdo principal
CygoLite Night Rover Rubber Charging Input Gasket Replacement
O que você precisa
  1. CygoLite Night Rover Rubber Charging Input Gasket Replacement, Rubber Charging Input Gasket: passo 1, imagem 1 %32 CygoLite Night Rover Rubber Charging Input Gasket Replacement, Rubber Charging Input Gasket: passo 1, imagem 2 %32 CygoLite Night Rover Rubber Charging Input Gasket Replacement, Rubber Charging Input Gasket: passo 1, imagem 3 %32
    • Place the CygoLite on a flat surface with the bottom side facing up.
    • Locate the four screws on the bottom of the device.
    • Unscrew them with a Phillips head screwdriver and remove the bottom casing.
  2. CygoLite Night Rover Rubber Charging Input Gasket Replacement: passo 2, imagem 1 %32 CygoLite Night Rover Rubber Charging Input Gasket Replacement: passo 2, imagem 2 %32
    • Locate the rubber gasket on the side of the device.
    • Place your new replacement rubber gasket onto the side of the casing and gently place the top of the case back on top of it.
    • Be sure to line up the grooves in the casing with the grooves on the rubber gasket.
Conclusão
Trent Vigar
Membro desde: 10/22/12
101 Reputação
Autoria de 1 guia
Equipe
Clemson, Team 14-3, Benson Fall 2012 Membro de Clemson, Team 14-3, Benson Fall 2012
CLEM-BENSON-F12S14G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 359
