Ir para o conteúdo principal
CyberpowerPC Fangbook HX6 Screen Replacement
O que você precisa
  1. CyberpowerPC Fangbook HX6 Screen Replacement, Screen: passo 1, imagem 1 %32
    • To replace the screen you will need a screwdriver (a size zero was used in this guide), and a tool that can be used to pry off the screen covering (a spudger was used in this guide).
  2. CyberpowerPC Fangbook HX6 Screen Replacement: passo 2, imagem 1 %32 CyberpowerPC Fangbook HX6 Screen Replacement: passo 2, imagem 2 %32 CyberpowerPC Fangbook HX6 Screen Replacement: passo 2, imagem 3 %32
    • Insert the spudger gently into the seam that connects the front plate to the rest of the device.
    • Move the tool carefully around the screen and apply a small amount of pressure. You are trying to undo several clasps holding the front plate on.
    • Do this on all sides of the face plate except for the bottom. The bottom will have a strip of adhesive you will need to carefully pull off to separate the face plate from the bottom of the screen.
  3. CyberpowerPC Fangbook HX6 Screen Replacement: passo 3, imagem 1 %32 CyberpowerPC Fangbook HX6 Screen Replacement: passo 3, imagem 2 %32
    • Remove the two 4mm silver screws on both sides of the top of the screen.
    • Once you have removed them, gently pull the screen off of the aligning dials (the small plastic pieces to the left of the screws).
  4. CyberpowerPC Fangbook HX6 Screen Replacement: passo 4, imagem 1 %32 CyberpowerPC Fangbook HX6 Screen Replacement: passo 4, imagem 2 %32
    • At this point the only thing keeping the screen attached to the laptop is this small wire and connector shown here.
    • Gently pull the screen out and turn it over so that you can see where the connector is attached.
    • Carefully remove it. Once this is done you have successfully removed the screen from your laptop.
Conclusão
Eric Box
Membro desde: 09/12/18
159 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 23
Duração total: 828
