Ir para o conteúdo principal
CyberPowerPC RGB 7 Color USB Outlet Replacement
O que você precisa
  1. CyberPowerPC RGB 7 Color USB Outlet Replacement, Plastic Casing: passo 1, imagem 1 %32 CyberPowerPC RGB 7 Color USB Outlet Replacement, Plastic Casing: passo 1, imagem 2 %32
    • Be sure to unplug the keyboard before starting the disassembly.
    • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
  2. CyberPowerPC RGB 7 Color USB Outlet Replacement: passo 2, imagem 1 %32 CyberPowerPC RGB 7 Color USB Outlet Replacement: passo 2, imagem 2 %32
    • Remove the sixteen 5 mm length screws using the Phillips head #2.
    • One of the screws may be located underneath a manufacturer's sticker.
  3. CyberPowerPC RGB 7 Color USB Outlet Replacement: passo 3, imagem 1 %32
    • Lift up and remove the plastic casing.
  4. CyberPowerPC RGB 7 Color USB Outlet Replacement, LED Backlight: passo 4, imagem 1 %32
    • Remove the metal backing located directly underneath the white plastic casing.
  5. CyberPowerPC RGB 7 Color USB Outlet Replacement: passo 5, imagem 1 %32
    • Be careful not to pull too hard on the ribbon cable, as it may break.
    • Disconnect the ribbon cable that connects the LED board to the motherboard.
  6. CyberPowerPC RGB 7 Color USB Outlet Replacement: passo 6, imagem 1 %32
    • Carefully remove the LED board, which should now come free from the casing.
  7. CyberPowerPC RGB 7 Color USB Outlet Replacement, USB Outlet: passo 7, imagem 1 %32
    • Remove the motherboard and its attached cable from the plastic casing. The cord should now be free and can be replaced.
Conclusão
Equipe
USF Tampa, Team S15-G2, Boczar Spring 2018 Membro de USF Tampa, Team S15-G2, Boczar Spring 2018
USFT-BOCZAR-S18S15G2
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 15
Duração total: 645
