Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
The case of the keyboard is plastic and can break. This guide will show how to replace the case of the keyboard.
Peças
Nenhum componente especificado.
  1. Be sure to unplug the keyboard before starting the disassembly. Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
    • Be sure to unplug the keyboard before starting the disassembly.
    • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
  2. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Remove the sixteen 5 mm length screws using the Phillips head #2. One of the screws may be located underneath a manufacturer's sticker.
    • Remove the sixteen 5 mm length screws using the Phillips head #2.
    • One of the screws may be located underneath a manufacturer's sticker.
  4. Lift up and remove the plastic casing.
    • Lift up and remove the plastic casing.
Conclusão
Braydon Lantz
Membro desde: 12-02-2018
193 Reputação
2 Guias de autoria
equipe
USF Tampa, Team S15-G2, Boczar Spring 2018 Membro de USF Tampa, Team S15-G2, Boczar Spring 2018
USFT-BOCZAR-S18S15G2
4 Membros
5 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 153
