Ir para o conteúdo principal
CyberPowerPC RGB 7 Color Motherboard Replacement
O que você precisa
  1. CyberPowerPC RGB 7 Color Motherboard Replacement, Plastic Casing: passo 1, imagem 1 %32 CyberPowerPC RGB 7 Color Motherboard Replacement, Plastic Casing: passo 1, imagem 2 %32
    • Be sure to unplug the keyboard before starting the disassembly.
    • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
  2. CyberPowerPC RGB 7 Color Motherboard Replacement: passo 2, imagem 1 %32 CyberPowerPC RGB 7 Color Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the sixteen 5 mm length screws using the Phillips head #2.
    • One of the screws may be located underneath a manufacturer's sticker.
  3. CyberPowerPC RGB 7 Color Motherboard Replacement: passo 3, imagem 1 %32
    • Lift up and remove the plastic casing.
  4. CyberPowerPC RGB 7 Color Motherboard Replacement, LED Backlight: passo 4, imagem 1 %32
    • Remove the metal backing located directly underneath the white plastic casing.
  5. CyberPowerPC RGB 7 Color Motherboard Replacement: passo 5, imagem 1 %32
    • Be careful not to pull too hard on the ribbon cable, as it may break.
    • Disconnect the ribbon cable that connects the LED board to the motherboard.
  6. CyberPowerPC RGB 7 Color Motherboard Replacement: passo 6, imagem 1 %32
    • Carefully remove the LED board, which should now come free from the casing.
  7. CyberPowerPC RGB 7 Color Motherboard Replacement, Motherboard: passo 7, imagem 1 %32
    • Now the cell membrane should be exposed, gently lift this part and ensure that the rubber buffers are all intact to the membrane, if not pick up the buffers and set to the side.
  8. CyberPowerPC RGB 7 Color Motherboard Replacement: passo 8, imagem 1 %32
    • Remove the motherboard and its attached cable from the plastic casing. The cord should now come free to replace.
Conclusão
Equipe
USF Tampa, Team S15-G2, Boczar Spring 2018 Membro de USF Tampa, Team S15-G2, Boczar Spring 2018
USFT-BOCZAR-S18S15G2
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 19
Duração total: 431
