Introdução
Over time the cable on the Motherboard may become loose or even break due to wear and tear. This guide will demonstrate how to replace the motherboard of the keyboard.
O que você precisa
Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
Remove the metal backing located directly underneath the white plastic casing.
Now the cell membrane should be exposed, gently lift this part and ensure that the rubber buffers are all intact to the membrane, if not pick up the buffers and set to the side.
