Ir para o conteúdo principal
CyberPowerPC Fangbook MS-1763 Battery Replacement
O que você precisa
  1. CyberPowerPC Fangbook MS-1763 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Save all of your work and turn off the laptop before beginning.
    • Close the laptop and flip it so that the bottom side is facing up.
    • Locate the battery compartment.
  2. CyberPowerPC Fangbook MS-1763 Battery Replacement: passo 2, imagem 1 %32
    • Pull the latches away from the battery compartment. The lid of the compartment should pop out of place.
  3. CyberPowerPC Fangbook MS-1763 Battery Replacement: passo 3, imagem 1 %32
    • Tilt the lid so that it leans away from the laptop and exposes the battery below.
    • Remove the battery from the newly opened compartment.
Conclusão
Insert a new battery and close the compartment lid to complete.
Uma outra pessoa concluiu este guia.
Um comentário
what is the battery name?
Jimmy Grant - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 1,048
