Ir para o conteúdo principal
CyberPower UPS Battery Replacement
O que você precisa
  1. CyberPower UPS Battery Replacement, Battery: passo 1, imagem 1 %32 CyberPower UPS Battery Replacement, Battery: passo 1, imagem 2 %32
    • Power down the unit by pressing the power button until the display goes black.
    • This is usually about 3 seconds.
    • Unplug the power cord from the wall outlet.
  2. CyberPower UPS Battery Replacement: passo 2, imagem 1 %32 CyberPower UPS Battery Replacement: passo 2, imagem 2 %32 CyberPower UPS Battery Replacement: passo 2, imagem 3 %32
    • Remove the battery plate cover at the bottom of the UPS using a Phillips #1 screwdriver.
    • If the screwdriver is not magnetized, tap on the cover plate to completely remove the screw.
  3. CyberPower UPS Battery Replacement: passo 3, imagem 1 %32 CyberPower UPS Battery Replacement: passo 3, imagem 2 %32
    • Slide the battery cover plate to the left.
    • Grasp the battery plate cover and lift it off the the UPS.
  4. CyberPower UPS Battery Replacement: passo 4, imagem 1 %32 CyberPower UPS Battery Replacement: passo 4, imagem 2 %32 CyberPower UPS Battery Replacement: passo 4, imagem 3 %32
    • Pull out the battery to expose the terminal connectors.
    • Use needlenose pliers to disconnect both battery terminal connectors.
    • Do not pull the connectors by the wires, pull connectors by grabbing the connector itself.
    • With the battery terminal connectors disconnected, slide the battery all the way out.
  5. CyberPower UPS Battery Replacement: passo 5, imagem 1 %32 CyberPower UPS Battery Replacement: passo 5, imagem 2 %32 CyberPower UPS Battery Replacement: passo 5, imagem 3 %32
    • The replacement battery should be a 12 volt, 9 amp-hour, sealed lead acid battery with f2 type connectors.
    • Install the new battery and reconnect the terminals.
  6. CyberPower UPS Battery Replacement: passo 6, imagem 1 %32 CyberPower UPS Battery Replacement: passo 6, imagem 2 %32 CyberPower UPS Battery Replacement: passo 6, imagem 3 %32
    • Insert the screw to secure the battery cover plate.
    • Tighten the screw with a Phillips #1 screwdriver.
  7. CyberPower UPS Battery Replacement: passo 7, imagem 1 %32 CyberPower UPS Battery Replacement: passo 7, imagem 2 %32 CyberPower UPS Battery Replacement: passo 7, imagem 3 %32
    • Plug system into the wall outlet.
    • Press the power button to turn on the unit.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 69
Últimos 30 dias: 316
Duração total: 12,666
