Ir para o conteúdo principal
CyberHome CH-DVD 300 Back Panel Replacement
O que você precisa
  1. CyberHome CH-DVD 300 Back Panel Replacement, Top Panel: passo 1, imagem 1 %32 CyberHome CH-DVD 300 Back Panel Replacement, Top Panel: passo 1, imagem 2 %32
    • Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD.
    • Unplug the DVD player from the wall socket.
    • Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
  2. CyberHome CH-DVD 300 Back Panel Replacement: passo 2, imagem 1 %32 CyberHome CH-DVD 300 Back Panel Replacement: passo 2, imagem 2 %32
    • Remove the top panel of the DVD Player by:
    • Sliding the top panel backwards.
    • Gently lifting the back of the top panel up.
  3. CyberHome CH-DVD 300 Back Panel Replacement, Back Panel: passo 3, imagem 1 %32 CyberHome CH-DVD 300 Back Panel Replacement, Back Panel: passo 3, imagem 2 %32
    • Remove the remaining screws on the back of the DVD player:
    • There will be four 15 mm screws and two 6.3 mm screws.
  4. CyberHome CH-DVD 300 Back Panel Replacement: passo 4, imagem 1 %32
    • Remove the back panel by:
    • Lifting up on the back panel.
    • Pulling the back panel backwards from the DVD player.
Conclusão
Uma outra pessoa concluiu este guia.
Chris Menezes
Membro desde: 04/07/14
642 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 6-5, Forte Spring 2014 Membro de Cal Poly, Team 6-5, Forte Spring 2014
CPSU-FORTE-S14S6G5
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 561
