Ir para o conteúdo principal
Cyber-Shot DSC-H55 Battery Replacement
  1. Cyber-Shot DSC-H55 Battery Replacement, Finding the battery compartment: passo 1, imagem 1 %32 Cyber-Shot DSC-H55 Battery Replacement, Finding the battery compartment: passo 1, imagem 2 %32
    • Before you begin it is important to know where the battery compartment is. The battery compartment is located on the bottom of the camera.
    • Place the camera upside down with the lens facing you so that the battery compartment is facing up.
    • Place your thumb on the lid of the battery compartment making sure you put some pressure.
  2. Cyber-Shot DSC-H55 Battery Replacement, Opening Battery Compartment: passo 2, imagem 1 %32 Cyber-Shot DSC-H55 Battery Replacement, Opening Battery Compartment: passo 2, imagem 2 %32 Cyber-Shot DSC-H55 Battery Replacement, Opening Battery Compartment: passo 2, imagem 3 %32
    • Grab the camera with one hand, with your thumb still on the lid, apply pressure and slide to the right.
    • Lift the lid, exposing the battery and SD slot.
  3. Cyber-Shot DSC-H55 Battery Replacement, Removing Battery: passo 3, imagem 1 %32
    • There is a small blue tab on the right of the compartment. In order to remove the battery, move this tab aside and the battery will pop up.
  4. Cyber-Shot DSC-H55 Battery Replacement, Inserting a New Battery: passo 4, imagem 1 %32 Cyber-Shot DSC-H55 Battery Replacement, Inserting a New Battery: passo 4, imagem 2 %32
    • Grab the new battery. Place the battery so that the arrow is pointing down and facing you. Next, slide the the battery into the battery compartment.
    • The blue tab will lock the battery into place.
Conclusão
Uma outra pessoa concluiu este guia.
Jazmin Young
Membro desde: 01/21/15
608 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 6-2, Brown Winter 2015 Membro de USF Tampa, Team 6-2, Brown Winter 2015
USFT-BROWN-W15S6G2
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 886
