Ir para o conteúdo principal
Cuisinart TOA-60FR Power Cord Replacement
O que você precisa
  1. Cuisinart TOA-60FR Power Cord Replacement, Outside removal: passo 1, imagem 1 %32
    • Using a 25-hexagon head, unscrew these 7.31 mm three screws.
  2. Cuisinart TOA-60FR Power Cord Replacement: passo 2, imagem 1 %32 Cuisinart TOA-60FR Power Cord Replacement: passo 2, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove all these 7.31 mm screws.
    • Pull off the back.
  3. Cuisinart TOA-60FR Power Cord Replacement: passo 3, imagem 1 %32 Cuisinart TOA-60FR Power Cord Replacement: passo 3, imagem 2 %32 Cuisinart TOA-60FR Power Cord Replacement: passo 3, imagem 3 %32
    • Flip the oven upside down.
    • Pick the grey stoppers out with a sprudger.
    • Using a Phillips #1 screwdriver, remove these three 11 mm screws.
  4. Cuisinart TOA-60FR Power Cord Replacement: passo 4, imagem 1 %32 Cuisinart TOA-60FR Power Cord Replacement: passo 4, imagem 2 %32
    • Unscrew all of the 11.05 mm screws that connect the outer shell to the device.
  5. Cuisinart TOA-60FR Power Cord Replacement: passo 5, imagem 1 %32 Cuisinart TOA-60FR Power Cord Replacement: passo 5, imagem 2 %32 Cuisinart TOA-60FR Power Cord Replacement: passo 5, imagem 3 %32
    • Pull the top piece off.
    • Push down before pulling up to release the tabs.
  6. Cuisinart TOA-60FR Power Cord Replacement, Power Cord: passo 6, imagem 1 %32
    • Take the needle nose pliers and cut off the crimped-on-wire connectors.
    • Pressed down hard. These wires are thick.
    • These are crimped on wire conncetors so they can not be twisted off. The only way to remove them is by cutting off the wire.
  7. Cuisinart TOA-60FR Power Cord Replacement: passo 7, imagem 1 %32 Cuisinart TOA-60FR Power Cord Replacement: passo 7, imagem 2 %32 Cuisinart TOA-60FR Power Cord Replacement: passo 7, imagem 3 %32
    • Strip the wires back with wire strippers. Or carefully take the needle nose pliers and cut gently to only make a mark on the jacket and not the wires. Then pull with the pliers to remove the jacket.
  8. Cuisinart TOA-60FR Power Cord Replacement: passo 8, imagem 1 %32 Cuisinart TOA-60FR Power Cord Replacement: passo 8, imagem 2 %32 Cuisinart TOA-60FR Power Cord Replacement: passo 8, imagem 3 %32
    • Take the white, blue, and black wire together and push togther
    • Then take the pliers and twist them until they are all combined.
  9. Cuisinart TOA-60FR Power Cord Replacement: passo 9, imagem 1 %32 Cuisinart TOA-60FR Power Cord Replacement: passo 9, imagem 2 %32
    • Crimp the wire connector with a crimper or pliers
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 50
Duração total: 222
