Ir para o conteúdo principal
Cuisinart TOA-60FR Function Switch Replacement
O que você precisa
  1. Cuisinart TOA-60FR Function Switch Replacement, Outside removal: passo 1, imagem 1 %32
    • Using a 25-hexagon head, unscrew these 7.31 mm three screws.
  2. Cuisinart TOA-60FR Function Switch Replacement: passo 2, imagem 1 %32 Cuisinart TOA-60FR Function Switch Replacement: passo 2, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove all these 7.31 mm screws.
    • Pull off the back.
  3. Cuisinart TOA-60FR Function Switch Replacement: passo 3, imagem 1 %32 Cuisinart TOA-60FR Function Switch Replacement: passo 3, imagem 2 %32 Cuisinart TOA-60FR Function Switch Replacement: passo 3, imagem 3 %32
    • Flip the oven upside down.
    • Pick the grey stoppers out with a sprudger.
    • Using a Phillips #1 screwdriver, remove these three 11 mm screws.
  4. Cuisinart TOA-60FR Function Switch Replacement: passo 4, imagem 1 %32 Cuisinart TOA-60FR Function Switch Replacement: passo 4, imagem 2 %32
    • Unscrew all of the 11.05 mm screws that connect the outer shell to the device.
  5. Cuisinart TOA-60FR Function Switch Replacement: passo 5, imagem 1 %32 Cuisinart TOA-60FR Function Switch Replacement: passo 5, imagem 2 %32 Cuisinart TOA-60FR Function Switch Replacement: passo 5, imagem 3 %32
    • Pull the top piece off.
    • Push down before pulling up to release the tabs.
  6. Cuisinart TOA-60FR Function Switch Replacement, Function Switch: passo 6, imagem 1 %32 Cuisinart TOA-60FR Function Switch Replacement, Function Switch: passo 6, imagem 2 %32 Cuisinart TOA-60FR Function Switch Replacement, Function Switch: passo 6, imagem 3 %32
    • Inside of the device locate the function switch and remove the indicated screws (4.97mm).
  7. Cuisinart TOA-60FR Function Switch Replacement: passo 7, imagem 1 %32
    • Unclip all connections.
    • Rotate function knob to broil so plastic tab is visible. Use screwdriver to push tab down and pull knob out from front side.
    • Remove 2 screws revealed under the front knob
Conclusão
Uma outra pessoa concluiu este guia.
TRiels
Membro desde: 09/08/23
118 Reputação
Autoria de 1 guia
Um comentário
Anyone have a source for a replacement switch?
Josh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 56
Últimos 30 dias: 165
Duração total: 842
