Ir para o conteúdo principal
Cuisinart Griddler GR-4N Cooking Surfaces Replacement
O que você precisa
  1. Cuisinart Griddler GR-4N Cooking Surfaces Replacement, Cooking Surfaces: passo 1, imagem 1 %32 Cuisinart Griddler GR-4N Cooking Surfaces Replacement, Cooking Surfaces: passo 1, imagem 2 %32
    • Ensure device is turned unplugged, cooled down and clean before attempting any replacements.
    • Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
  2. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: passo 2, imagem 1 %32
    • Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
  3. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: passo 3, imagem 1 %32
    • Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
  4. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: passo 4, imagem 1 %32
    • Remove the single 5.5 mm Phillips #2 screw next to center black button.
    • After removing the center screw the metal plate should be free to remove.
  5. Cuisinart Griddler GR-4N Cooking Surfaces Replacement: passo 5, imagem 1 %32 Cuisinart Griddler GR-4N Cooking Surfaces Replacement: passo 5, imagem 2 %32
    • Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
    • Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
    • The aligned parts will allow the cooking surfaces to work properly.
Conclusão
Uma outra pessoa concluiu este guia.
Kayla Londono
Membro desde: 04/15/16
632 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 1-12, Maness Spring 2016 Membro de Cal Poly, Team 1-12, Maness Spring 2016
CPSU-MANESS-S16S1G12
Membros da 4
Autoria de 6 guias
Um comentário
The 'cooking plates' on my unit always fall off. I tried bending the tabs to make it tighter - did not help. Any ideas?
M S - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 25
Duração total: 4,099
