Ir para o conteúdo principal
Cuisinart Griddler GR- 4N Knobs Replacement
O que você precisa
  1. Cuisinart Griddler GR- 4N Knobs Replacement, Cooking Surfaces: passo 1, imagem 1 %32 Cuisinart Griddler GR- 4N Knobs Replacement, Cooking Surfaces: passo 1, imagem 2 %32
    • Ensure device is turned unplugged, cooled down and clean before attempting any replacements.
    • Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
  2. Cuisinart Griddler GR- 4N Knobs Replacement: passo 2, imagem 1 %32
    • Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
  3. Cuisinart Griddler GR- 4N Knobs Replacement: passo 3, imagem 1 %32
    • Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
  4. Cuisinart Griddler GR- 4N Knobs Replacement: passo 4, imagem 1 %32
    • Remove the single 5.5 mm Phillips #2 screw next to center black button.
    • After removing the center screw the metal plate should be free to remove.
  5. Cuisinart Griddler GR- 4N Knobs Replacement: passo 5, imagem 1 %32 Cuisinart Griddler GR- 4N Knobs Replacement: passo 5, imagem 2 %32
    • Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
    • Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
    • The aligned parts will allow the cooking surfaces to work properly.
  6. Cuisinart Griddler GR- 4N Knobs Replacement, Cuisinart Griddler GR- 4N Disassembly: passo 6, imagem 1 %32
    • Remove the two 6 mm Phillips #2 screws that secure the knob circuit board.
    • Move the circuit board to the side so it is out of the way.
  7. Cuisinart Griddler GR- 4N Knobs Replacement: passo 7, imagem 1 %32
    • Remove the two 6 mm Phillips #2 screws that secure the white plastic LED holder.
  8. Cuisinart Griddler GR- 4N Knobs Replacement, Knobs: passo 8, imagem 1 %32
    • Pinch back plastic arms on knob while pulling out the knob.
  9. Cuisinart Griddler GR- 4N Knobs Replacement: passo 9, imagem 1 %32
    • Pop the new knob back into the hole and the repair is complete.
Conclusão
Kayla Londono
Membro desde: 04/15/16
632 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 1-12, Maness Spring 2016 Membro de Cal Poly, Team 1-12, Maness Spring 2016
CPSU-MANESS-S16S1G12
Membros da 4
Autoria de 6 guias
15 comentários
Where do you find the replacement knobs?
Chris Reece - Responder
Wish I knew! I need two knobs. Are their universal knobs out there that can be substituted?
sfk -
im in same boat can't find the dials/knobs- 2 of mine are broken and useless
Mark Stevens - Responder
Cuisinart offers NO help. I will have to toss out a $100.00 unit over a $2.00 part.
Nick - Responder
I have several cuisinart appliances. I won't ever buy another. I need one replacement knob, the best they can do is 20 percent off on a new griddler . I can get that from bed bath and beyond. Thanks cuisinart, finding new brands. Cuisinart is dead to me.
allen brathwaite - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 77
Duração total: 10,306
