Ir para o conteúdo principal
Cuisinart DCC-3200 Hot Plate Replacement
O que você precisa
  1. Cuisinart DCC-3200 Hot Plate Replacement, Hot Plate: passo 1, imagem 1 %32
    • Unplug the device and flip it over so the bottom is facing upwards.
    • Remove the four screws.
    • Remove the bottom panel.
  2. Cuisinart DCC-3200 Hot Plate Replacement: passo 2, imagem 1 %32
    • Remove the two screws from the silver brace.
  3. Cuisinart DCC-3200 Hot Plate Replacement: passo 3, imagem 1 %32 Cuisinart DCC-3200 Hot Plate Replacement: passo 3, imagem 2 %32
    • Use a spudger to wedge the red tube off of the metal.
    • Repeat this for the other side of the silver pipe deeper in the device.
  4. Cuisinart DCC-3200 Hot Plate Replacement: passo 4, imagem 1 %32
    • Pick up the middle pipe and slide the hot plate out of its area.
    • Apply new thermal paste to the hot plate.
Conclusão
Hamad Khan
Membro desde: 03/04/16
385 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 8-3, Botvin Spring 2016 Membro de UMass Dartmouth, Team 8-3, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G3
Membros da 3
Autoria de 3 guias
5 comentários
Where can one purchase the burner plate?
john Vet - Responder
Same question as John Vet
Bob Stimson - Responder
Did anyone ever get a response as to where a replacement could be purchased?
Joe Lubrant -
Did response provide required info?
Joe Lubrant - Responder
Same question: where can we purchase the burner plate?
Cresny - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 28
Últimos 30 dias: 110
Duração total: 4,864
