Introdução
Is the handle on the carafe of your Cuisinart coffee maker lose or damaged? If so, this guide will provide instructions on how to replace the handle on the carafe. To complete this task all you will need is a bit driver with the PH1 Phillips bit.
O que você precisa
Wedge the metal spudger between the plug and the handle.
Carefully pry the plug with the metal spudger by applying pressure around the plug.
3 outras pessoas executaram este guia.
Um comentário
I needed this guide after my spouse put the carafe in the dishwasher and the handle sloshed no matter how much I shook it. It turns out water is easily trapped under the top cap; even though there's a drain hole into the handle, it doesn't seem to want to drain. I've wiped it off and left it to dry completely before reassembling it.
