Ir para o conteúdo principal
Cuisinart DCC-1200 Coffee Carafe Handle Replacement
O que você precisa
  1. Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: passo 1, imagem 1 %32 Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: passo 1, imagem 2 %32 Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: passo 1, imagem 3 %32
    • Wedge the metal spudger between the plug and the handle.
    • Carefully pry the plug with the metal spudger by applying pressure around the plug.
    • Too much pressure and prying can damage the plug.
  2. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: passo 2, imagem 1 %32 Cuisinart DCC-1200 Coffee Carafe Handle Replacement: passo 2, imagem 2 %32
    • Use the bit driver with the Phillips PH1 bit to remove the 27 millimeter long screw in the base of the handle.
  3. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: passo 3, imagem 1 %32
    • Lift up on and remove the lid from the carafe.
  4. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: passo 4, imagem 1 %32 Cuisinart DCC-1200 Coffee Carafe Handle Replacement: passo 4, imagem 2 %32
    • Position the metal spudger underneath the top cap of the handle.
    • Gently pry up to extract the upper assembly cap.
    • Pry carefully to prevent from causing aesthetic damage to upper assembly cap.
  5. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: passo 5, imagem 1 %32
    • Use the bit driver with the Phillips PH1 to remove the 5 millimeter screw in upper assembly of handle.
    • Remove handle by lifting straight up.
Conclusão
3 outras pessoas executaram este guia.
Austin Wheaton
Membro desde: 02/15/18
861 Reputação
Autoria de 4 guias
Equipe
UW Stout, Team S8-G1, Ogden Spring 2018 Membro de UW Stout, Team S8-G1, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G1
Membros da 4
Autoria de 5 guias
Um comentário
I needed this guide after my spouse put the carafe in the dishwasher and the handle sloshed no matter how much I shook it. It turns out water is easily trapped under the top cap; even though there's a drain hole into the handle, it doesn't seem to want to drain. I've wiped it off and left it to dry completely before reassembling it.
Max - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 35
Duração total: 3,729
