Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Is your Cuisinart coffee maker producing cold coffee even though all internal connections are intact? If so, this guide will provide instructions on how to replace the heating element in the bottom of the machine. To complete this task all you will need is a soldering iron, a PH1 driver bit and a T10 driver bit.
O que você precisa
Flip the coffee maker over so the bottom is facing up.
Use the screwdriver with size 4 extension with the T10 Torx bit to remove all four 17 mm long screws.
Lift the bottom cover off the bottom of the coffee maker.
8 outras pessoas executaram este guia.
18 comentários
Where do you find a replacement heating element?
I have a Cusinart DCC-2600 coffee maker that has stopped heating. I suspect the heating element needs replacing. The bottom of the maker looks very similar to the DCC-1200 shown above, but the 4 screws that hold the bottom on my model do not have any torx heads. They feel more like a rivet?!
Is this to make it not serviceable or am I missing something? If anyone has a suggestion, please respond
Hi Dave,
Here, I’ve Cuisinart DCC-1400 coffee maker but the 4 screws on bottom is a torx with the pin in the center.
Check this , you need probably a torx driver with the hole in the center !
Jos
Jos -
Agree - any assistance in finding the replacement heating element would be most helpful. I have this coffee maker, and the metal clamp holding the heating element in place corroded through. Now the hotplate falls away from the bottom of the coffee maker. I’d like to replace the heating element and I assume it comes with the clamp in place - but cuisinart does not make any internal parts available to online parts retailers. Thanks!
