Ir para o conteúdo principal
Cuisinart DCC-1200 Heating Element Replacement
O que você precisa
  1. Cuisinart DCC-1200  Heating Element Replacement, Heating Element: passo 1, imagem 1 %32 Cuisinart DCC-1200  Heating Element Replacement, Heating Element: passo 1, imagem 2 %32 Cuisinart DCC-1200  Heating Element Replacement, Heating Element: passo 1, imagem 3 %32
    • Flip the coffee maker over so the bottom is facing up.
    • Use the screwdriver with size 4 extension with the T10 Torx bit to remove all four 17 mm long screws.
    • Lift the bottom cover off the bottom of the coffee maker.
    This looks simple, even before I watched the video. The hard part is finding the new heating element. I can't find it. Where'd you get it?
    Steve Langevin - Responder
    Heating Element Dc312TtcPart #: EH1257
    Thermal fuse 10A 240c on Amazon
    Ohio Benz - Responder
    Should the heating element be open circuit if failed?
    Dave Peel - Responder
  2. Cuisinart DCC-1200  Heating Element Replacement: passo 2, imagem 1 %32 Cuisinart DCC-1200  Heating Element Replacement: passo 2, imagem 2 %32 Cuisinart DCC-1200  Heating Element Replacement: passo 2, imagem 3 %32
    • Squeeze the hose clamps together and begin moving the metal clamp away from the heating element.
    • Gently pull on the loose hose to remove it from the heating element.
  3. Cuisinart DCC-1200  Heating Element Replacement: passo 3, imagem 1 %32 Cuisinart DCC-1200  Heating Element Replacement: passo 3, imagem 2 %32
    • Repeat previous step to disconnect the other attached water hose.
  4. Cuisinart DCC-1200  Heating Element Replacement: passo 4, imagem 1 %32 Cuisinart DCC-1200  Heating Element Replacement: passo 4, imagem 2 %32
    • Use the bit driver with the extension attachment with the PH1 Phillips bit to remove the two 18mm long screws on heating element plate.
  5. Cuisinart DCC-1200  Heating Element Replacement: passo 5, imagem 1 %32 Cuisinart DCC-1200  Heating Element Replacement: passo 5, imagem 2 %32
    • If heating contacts are connected, use a soldering iron to desolder the bond between metal contact points.
    • Solder iron can cause burns if used improperly
  6. Cuisinart DCC-1200  Heating Element Replacement: passo 6, imagem 1 %32 Cuisinart DCC-1200  Heating Element Replacement: passo 6, imagem 2 %32 Cuisinart DCC-1200  Heating Element Replacement: passo 6, imagem 3 %32
    • Remove the heating element clamp and set aside to access the heating element.
    • Gently squeeze and pull up on metal clamp attached to the heating element.
  7. Cuisinart DCC-1200  Heating Element Replacement: passo 7, imagem 1 %32
    • Remove and replace the defective heating element.
    Do you have a link to the heating element? Do you know if other models have the same element?
    Tristan Reynolds - Responder
    Where did you get the heating element from????
    MP -
    Great tutorial…looking for the heating element too? Source?. I am waiting for callback from Cuisinart, but not holding my breath based on what I see here.
    Charou - Responder
    Had the same problem on 2 Cuisinart coffee maker. Impossible to get spare parts, even directly at Cuisinart... Poorly designed, won't buy again.
    madscouts -
    How do you know that the heating element is bad. Mind is intact but the machine grinds and gets stuck, it doesn’t advance to the brewing phase that is. Maybe I should test the heating element for continuity?
    Hussein chahine - Responder
    Great instructions!
    So far impossible to get a replacement element :(
    Thx!
    MrFixIt - Responder
Conclusão
8 outras pessoas executaram este guia.
Austin Wheaton
Membro desde: 02/15/18
861 Reputação
Autoria de 4 guias
Equipe
UW Stout, Team S8-G1, Ogden Spring 2018 Membro de UW Stout, Team S8-G1, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G1
Membros da 4
Autoria de 5 guias
18 comentários
Where do you find a replacement heating element?
Evan Dunville - Responder
Finding the replacement heater element is the real challenge:)
vvaccaro - Responder
I have a Cusinart DCC-2600 coffee maker that has stopped heating. I suspect the heating element needs replacing. The bottom of the maker looks very similar to the DCC-1200 shown above, but the 4 screws that hold the bottom on my model do not have any torx heads. They feel more like a rivet?!
Is this to make it not serviceable or am I missing something? If anyone has a suggestion, please respond
Dave Schultz - Responder
Hi Dave,
Here,  I’ve Cuisinart DCC-1400 coffee maker but the 4 screws  on bottom is a torx with the pin in the center.
Check this , you need probably a torx driver with the hole in the center !
Jos
Jos -
Agree - any assistance in finding the replacement heating element would be most helpful. I have this coffee maker, and the metal clamp holding the heating element in place corroded through. Now the hotplate falls away from the bottom of the coffee maker. I’d like to replace the heating element and I assume it comes with the clamp in place - but cuisinart does not make any internal parts available to online parts retailers. Thanks!
David Miller - Responder
Yes - the torx screws with pins in the middle are security screws - designed to not be removable by most people. An additional challenge is these screws are rather deep-set, so you need an actual security torx driver, not just a bit set. I found a set of torx drivers which included the holes even though they weren’t labeled as such - check your local major home store retailer next to the hex wrenches.
I appreciate the great responses and help. Aside from not being able to find the right torx drivers to remove the bottom access panel, the bigger problem was not being able to find a replacement heating element. I gave up end put it in the trash.
I have a Black and Decker model that is working fine.
Done.
Thanks for posting this, good pictures and nice and clear guidance.  I am also struggling to find a replacement unit though. Dave Miller’s post is telling, so Cuisnart do not support repair of their machines…This must be a business opportunity for someone, a 1000w heater and heat sink unit is not rocket science.
john pearce - Responder
How to buy heating element sir?
Restetuto Gatase - Responder
My coffee maker has the opposite issue…the heating element boils the water away! How do I lower the temperature?
jonrugh - Responder
The most likely issue in your case is the non functioning valve inside one of the tubes. That valve is what enables water to move and make your coffee.
Denis Romanenko -
Cuisinart Drip Coffee Maker:
Model CBC-6500PCC
In use:
Less than one year.
Problem:
Not heating
Cause:
Blown thermal fuse (240C) connected in series with one side of heating element (there are two, each one connected in series and attached directly to each side of the heating element.) Not replaceable by itself.
Remedy:
Replacement under warranty or purchase a used one at Goodwill, Salvation Army, Value Village, local online personal seller, etc.
brian.steven.richmond - Responder
Hi I have cuisinart DGB-900bc and the power reaches the machine but no water coming to the coffee basket and no heating on the element ?
((sorry of there any spelling mistake English is not my first language ))
Ali Alsopey - Responder
I have a DCC 1400 and it overflowed during a brew cycle, and was sitting in a tray which collected the overflow and unfortunately water/liquid got in the bottom through the grill and I suspect it fried the heating element and I will test with my meter. My element looks identical to the pics above for the DCC 1200 so I assume it is the same one. Does anyone know what that component is that is held against the heater with the metal clamp - as referred to in step 6 above with the two yellow wires attached? Mine is quite corroded so will clean that up and see if that helps.
Regarding a replacement heating element, it looks like this may be compatible — can anyone confirm?
https://www.ereplacementparts.com/heatin...
SteveH - Responder
The useful manual would contain information on where to get replacement part to begin with. This one is one has usefulness value of 3 on 1000 scale
Denis Romanenko - Responder
I really like the Cuisinart brand of coffee makers, however it !#^&@! me off they do not provide repair parts. So I took the failed, 6 year old DCC-3200 unit apart today. I removed the failed heater element, it looks a little different than the photo above. However the OEM is Kaneta Electric (I tracked them down to be based in Hong Kong) part number FP1001 120volt, 1050watt, coil whihc is adhered to the underside of the burner plate the coffee pot rests on. I was not able to buy a replacement part, however some of you other clever, internet saavy folks may be able to source it. If you do, please kindly update this web page. So, the replacement $99 coffee maker from Cuisinart is now on order - just the way they planned. God love ‘em as my father in law used to say.
jim bixby - Responder
I have a DGB-900BC Burr Grind and Brew, bought from Amazon to replace my old one.
I kept it in the box until I give my other one away, and upon trying to use it, I find it does everything right EXCEPT boil the water.
So I open it up thinking it might be a relay or worse something wrong with the controller, the first thing I check is the resistance of the heating element, which turned out to be zero, of course diagnosing it as the likely problem. I put some test clips and a VOM on the ends of the heating element connections, and ran the thing, the voltage is there when it is supposed to be, but the element is busted.
Now, like everyone here -- WTF do I buy the replace part?? I am fortunate that I have not thrown away my ole one and can swap that out, but really why can I buy a replacement part?
G Trieste - Responder
My burner plate is corroded. Can it be replaced?
Kelly Butler - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 33
Últimos 30 dias: 166
Duração total: 16,145
