Ir para o conteúdo principal
Cuisinart DCC-1100 Hot Plate Replacement
O que você precisa
  1. Cuisinart DCC-1100 Hot Plate Replacement, Hot Plate: passo 1, imagem 1 %32
    • Unplug the coffee maker.
  2. Cuisinart DCC-1100 Hot Plate Replacement: passo 2, imagem 1 %32
    • Remove the coffee pot and place the coffee maker upside down.
  3. Cuisinart DCC-1100 Hot Plate Replacement: passo 3, imagem 1 %32
    • Remove the five 1.6mm Phillips #1 screws from the bottom panel.
  4. Cuisinart DCC-1100 Hot Plate Replacement: passo 4, imagem 1 %32
    • Remove the bottom panel.
  5. Cuisinart DCC-1100 Hot Plate Replacement: passo 5, imagem 1 %32
    • Remove the two 1.6mm Phillips #0 screws from the retaining bracket on the heating element.
  6. Cuisinart DCC-1100 Hot Plate Replacement: passo 6, imagem 1 %32
    • Remove the retaining bracket and allow it to hang off of the heating element.
  7. Cuisinart DCC-1100 Hot Plate Replacement: passo 7, imagem 1 %32
    • Remove the hot plate from the heating element.
    • New thermal paste should be applied at time of installation.
Conclusão
4 outras pessoas executaram este guia.
Josh Harvey
Membro desde: 01/25/18
886 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S20-G4, Passmore Spring 2018 Membro de USF Tampa, Team S20-G4, Passmore Spring 2018
USFT-PASSMORE-S18S20G4
Membros da 4
Autoria de 7 guias
13 comentários
thank you for this informative display.
I have broken many expensive glass carafs for my cuisinart coffeemaker and finally purchased a cuisinart thermal caraf.
I do not need the hotplate to heat, so what do I do to stop the heating process?
I imagine I would need to remove one of the attached lines to the heating element, yes?
Thanks.
Luciano
luciano1213@msn.com
Luciano Muzzatti - Responder
Hi, Thanks for sharing this information. I have an older Krups coffee maker that still works great but the hot plate is warn. I cannot seem to find a replacement plate for any Krups coffee maker models. Any suggestions? Thanks!
Paulette Paglia - Responder
Josh
where do I buy the replacement hot plate?? I have the sis 15 coffeemaker and I have googled all over the place?? Thank u
linkev428 - Responder
Yes, where do you buy the part??
Kathy Johnston - Responder
Yes my question is where do you get the new hot plate? Any direction appreciated.
DougB - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 28
Duração total: 6,099
