Ir para o conteúdo principal
Cuisinart CPT-140BK Circuit Board Replacement
O que você precisa
  1. Cuisinart CPT-140BK  Circuit Board Replacement, Circuit Board: passo 1, imagem 1 %32
    • Unplug the toaster before disassembly.
  2. Cuisinart CPT-140BK  Circuit Board Replacement: passo 2, imagem 1 %32 Cuisinart CPT-140BK  Circuit Board Replacement: passo 2, imagem 2 %32
    • Turn the toaster upside down.
    • Unscrew all 4mm screws using Phillips #2 screwdriver.
  3. Cuisinart CPT-140BK  Circuit Board Replacement: passo 3, imagem 1 %32
    • Turn the toaster right side up.
    • Lift up the front cover carefully because the cables can be damaged.
    • Pull out the toaster lever knobs by pulling it away from the toaster before removing the top cover.
  4. Cuisinart CPT-140BK  Circuit Board Replacement: passo 4, imagem 1 %32 Cuisinart CPT-140BK  Circuit Board Replacement: passo 4, imagem 2 %32 Cuisinart CPT-140BK  Circuit Board Replacement: passo 4, imagem 3 %32
    • Detach the cable that connects the toaster to the circuit board, in both control panels.
  5. Cuisinart CPT-140BK  Circuit Board Replacement: passo 5, imagem 1 %32
    • Carefully lift up the top cover.
  6. Cuisinart CPT-140BK  Circuit Board Replacement: passo 6, imagem 1 %32 Cuisinart CPT-140BK  Circuit Board Replacement: passo 6, imagem 2 %32 Cuisinart CPT-140BK  Circuit Board Replacement: passo 6, imagem 3 %32
    • The circuit board is located inside the front cover.
    • Unscrew total of six 4mm screws that attach each circuit board to the top cover, using Phillips #2 screwdriver.
    • Remove and replace the circuit board.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 653
