O que você precisa
Turn the device upside down.
Remove all four rubber feet by prying them out using the metal spudger.
Once the rubber feet have been removed, use the Phillips #2 screwdriver to remove all four 13mm screws.
Remove the 2 black, yellow, and red wires from circuit board by push down on the tab to release and then pull up.
Quase terminado!
Conclusão
