Ir para o conteúdo principal
Cuisinart CPB-380 Motor Replacement
O que você precisa
  1. Cuisinart CPB-380 Motor Replacement, Cuisinart CPB-380 Disassembly: passo 1, imagem 1 %32 Cuisinart CPB-380 Motor Replacement, Cuisinart CPB-380 Disassembly: passo 1, imagem 2 %32 Cuisinart CPB-380 Motor Replacement, Cuisinart CPB-380 Disassembly: passo 1, imagem 3 %32
    • Turn the device upside down.
    • Remove all four rubber feet by prying them out using the metal spudger.
    • Once the rubber feet have been removed, use the Phillips #2 screwdriver to remove all four 13mm screws.
  2. Cuisinart CPB-380 Motor Replacement: passo 2, imagem 1 %32 Cuisinart CPB-380 Motor Replacement: passo 2, imagem 2 %32
    • Remove the base from the body of the blender.
  3. Cuisinart CPB-380 Motor Replacement: passo 3, imagem 1 %32 Cuisinart CPB-380 Motor Replacement: passo 3, imagem 2 %32 Cuisinart CPB-380 Motor Replacement: passo 3, imagem 3 %32
    • Remove the two 11mm screws securing the power cord using the Phillips #2 screwdriver.
    • Gently move the wire aside so that it is not in the way.
  4. Cuisinart CPB-380 Motor Replacement: passo 4, imagem 1 %32 Cuisinart CPB-380 Motor Replacement: passo 4, imagem 2 %32 Cuisinart CPB-380 Motor Replacement: passo 4, imagem 3 %32
    • Remove the four 13mm screws that hold the black plastic cover using the Phillips #2 screwdriver.
    • Gently remove the black cover.
    • Underneath, you will see a clear plastic cover that should be removed as well.
  5. Cuisinart CPB-380 Motor Replacement: passo 5, imagem 1 %32 Cuisinart CPB-380 Motor Replacement: passo 5, imagem 2 %32
    • Cut the zip tie that holds the black, blue, red, and yellow wires together.
    • Take care not to cut the wires.
  6. Cuisinart CPB-380 Motor Replacement, Motor: passo 6, imagem 1 %32 Cuisinart CPB-380 Motor Replacement, Motor: passo 6, imagem 2 %32
    • Remove the four 13mm screws holding down the frame located at the bottom of the inverted blender using the Phillips #2 screwdriver.
    • Remove frame.
  7. Cuisinart CPB-380 Motor Replacement: passo 7, imagem 1 %32 Cuisinart CPB-380 Motor Replacement: passo 7, imagem 2 %32
    • Grab the motor by the black gear and the white filter.
    • Unscrew the black gear.
  8. Cuisinart CPB-380 Motor Replacement: passo 8, imagem 1 %32 Cuisinart CPB-380 Motor Replacement: passo 8, imagem 2 %32 Cuisinart CPB-380 Motor Replacement: passo 8, imagem 3 %32
    • With the metal spudger remove the four rubber stoppers.
    • Remove the four 13mm screws with the Phillips #2 screwdriver.
  9. Cuisinart CPB-380 Motor Replacement: passo 9, imagem 1 %32
    • Separate the top from the motor.
    • Pinch perpendicular to the flat surface and pull out the blue wire.
Conclusão
2 comentários
What is the part number and price for Cuisinart CPB-380 Motor?
Paul Hagen - Responder
What is the part number and price for Cuisinart CBD-380 motor and price....
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 54
Duração total: 3,182
