Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Unplug the coffee-maker from the power source.
Use a Phillips head screwdriver to remove the four 7mm screws from the back and the three 8mm screws from the bottom. This will release the bottom cover.
Use tweezers to remove the two rubber feet marked within the provided pictures.
Remove both 8mm Phillips head screws found within the holes where the feet were just removed.
Carefully pull the cover off the bottom of the coffee maker. This will give you access to the inside of the coffee maker.
Pull the gray ribbon cable strait out of the black containment box.
Locate the Phillips head screws holding the highlighted plastic shield in place.
Remove the two 14mm screws with a Phillips head screwdriver.
Carefully slide the shield out of place along the power cord and set it aside.
Remove the two 14mm Phillips head screws securing the plastic containment box.
Pull the plastic containment box straight out of the coffee maker.
Remove the four 11mm Phillips head screws in each corner of the plastic containment box.
Pull the top from the plastic housing.
Pull the circuit board out of the containment box.
Locate the power cable connection point on the circuit board.
Desolder the power cable wires connected to the board.
Replace the power cable with the corresponding wires of the new power cable.
