Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
Having problems powering-up your Cuisinart coffee-maker? Follow these instructions on how to replace Cuisinart CHW-12 power cord. This repair will only fix power issues directly related to the power cord. If the cord has been disconnected from the circuit board or severed a new power cord will be required to fix the issue. To successfully complete this guide you will need to know how to solder.
  1. Unplug the coffee-maker from the power source. Use a Phillips head screwdriver to remove the four 7mm screws from the back and the three 8mm screws from the bottom. This will release the bottom cover.
    • Unplug the coffee-maker from the power source.
    • Use a Phillips head screwdriver to remove the four 7mm screws from the back and the three 8mm screws from the bottom. This will release the bottom cover.
  2. Use tweezers to remove the two rubber feet marked within the provided pictures. Remove both 8mm Phillips head screws found within the holes where the feet were just removed.
    • Use tweezers to remove the two rubber feet marked within the provided pictures.
    • Remove both 8mm Phillips head screws found within the holes where the feet were just removed.
  3. Carefully pull the cover off the bottom of the coffee maker. This will give you access to the inside of the coffee maker. Pull the gray ribbon cable strait out of the black containment box. Pull the gray ribbon cable strait out of the black containment box.
    • Carefully pull the cover off the bottom of the coffee maker. This will give you access to the inside of the coffee maker.
    • Pull the gray ribbon cable strait out of the black containment box.
  4. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Locate the Phillips head screws holding the highlighted plastic shield in place. Remove the two 14mm screws with a Phillips head screwdriver. Carefully slide the shield out of place along the power cord and set it aside.
    • Locate the Phillips head screws holding the highlighted plastic shield in place.
    • Remove the two 14mm screws with a Phillips head screwdriver.
    • Carefully slide the shield out of place along the power cord and set it aside.
  6. Remove the two 14mm Phillips head screws securing the plastic containment box. Pull the plastic containment box straight out of the coffee maker. Pull the plastic containment box straight out of the coffee maker.
    • Remove the two 14mm Phillips head screws securing the plastic containment box.
    • Pull the plastic containment box straight out of the coffee maker.
  7. Remove the four 11mm Phillips head screws in each corner of the plastic containment box. Pull the top from the plastic housing.
    • Remove the four 11mm Phillips head screws in each corner of the plastic containment box.
    • Pull the top from the plastic housing.
  8. Pull the circuit board out of the containment box. Locate the power cable connection point on the circuit board. Desolder the power cable wires connected to the board.
    • Pull the circuit board out of the containment box.
    • Locate the power cable connection point on the circuit board.
    • Desolder the power cable wires connected to the board.
    • Solder iron can cause burns if used improperly.
    • Replace the power cable with the corresponding wires of the new power cable.
Conclusão
2 outras pessoas concluíram este guia.
Trevor Aspinall
Membro desde: 22-03-2018
343 Reputação
2 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 14
Duração total: 266
