Ir para o conteúdo principal
CubiCubi 47 Inch Computer Desk Keyboard Tray Replacement
O que você precisa
  1. CubiCubi 47 Inch Computer Desk Keyboard Tray Replacement, Keyboard Tray: passo 1, imagem 1 %32
    • Pull out the desk tray so it's fully extended.
  2. CubiCubi 47 Inch Computer Desk Keyboard Tray Replacement: passo 2, imagem 1 %32 CubiCubi 47 Inch Computer Desk Keyboard Tray Replacement: passo 2, imagem 2 %32 CubiCubi 47 Inch Computer Desk Keyboard Tray Replacement: passo 2, imagem 3 %32
    • Remove each of the 1.5 mm hex socket tray pillar screws with your screwdriver. Repeat for each corner.
    • Save these screws to reattach the tray later.
  3. CubiCubi 47 Inch Computer Desk Keyboard Tray Replacement: passo 3, imagem 1 %32
    • Detach the tray from the desk.
  4. CubiCubi 47 Inch Computer Desk Keyboard Tray Replacement: passo 4, imagem 1 %32 CubiCubi 47 Inch Computer Desk Keyboard Tray Replacement: passo 4, imagem 2 %32
    • Tighten the four side screws on the tray.
  5. CubiCubi 47 Inch Computer Desk Keyboard Tray Replacement: passo 5, imagem 1 %32 CubiCubi 47 Inch Computer Desk Keyboard Tray Replacement: passo 5, imagem 2 %32
    • Tighten the four screws connecting the tray pillar and the tray track.
  6. CubiCubi 47 Inch Computer Desk Keyboard Tray Replacement: passo 6, imagem 1 %32 CubiCubi 47 Inch Computer Desk Keyboard Tray Replacement: passo 6, imagem 2 %32
    • Screw the tray pillars back on the desk with the 1.5 mm Hex socket screws. Repeat for each four corners.
    • Reattaching the screws alone may be difficult. Try using a small table to hold the tray up or you may need another person to help.
Conclusão
Alex
Membro desde: 01/26/23
133 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 2-1, Morris Winter 2023 Membro de UC Davis, Team 2-1, Morris Winter 2023
UCD-MORRIS-W23S2G1
2 Membros
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 424
