Ir para o conteúdo principal
Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement
O que você precisa
  1. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement, Recoil Starter: passo 1, imagem 1 %32
    • Remove the four screws from the hood of the lawnmower using a Phillips #0 screwdriver.
  2. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 2, imagem 1 %32 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 2, imagem 2 %32 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 2, imagem 3 %32
    • Remove the hood of the lawnmower by pulling up.
  3. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 3, imagem 1 %32 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 3, imagem 2 %32 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 3, imagem 3 %32
    • Using a wrench, remove the three nuts from the lawnmower’s defective recoil starter.
  4. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 4, imagem 1 %32 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 4, imagem 2 %32 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 4, imagem 3 %32
    • Remove the defective recoil starter by pulling up.
  5. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 5, imagem 1 %32 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 5, imagem 2 %32 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 5, imagem 3 %32
    • Place the new recoil starter in the lawnmower where the defective one was prior.
  6. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 6, imagem 1 %32 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 6, imagem 2 %32 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 6, imagem 3 %32
    • Tighten the new recoil starter onto the lawnmower with a wrench and the nuts you had removed earlier.
  7. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 7, imagem 1 %32 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 7, imagem 2 %32 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 7, imagem 3 %32
    • Tighten the hood back onto the lawnmower with a Phillips #0 screwdriver and the four screws you had removed previously.
    • Make sure not to screw the hood on too tightly.
Linha de Chegada
Andres Dominguez
Membro desde: 01/26/22
145 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 44
Ao todo: 2,214
