1. Flip your bike so the seat and handlebars are on the ground.
    • Flip your bike so the seat and handlebars are on the ground.
  2. Slip the chain onto the crank and rear cog. Then insert wheel into rear drop-outs.
    • Slip the chain onto the crank and rear cog. Then insert wheel into rear drop-outs.
    • Make sure that the chain is on the correct side of the wheel
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Tighten brake strap using screwdriver and 10mm socket wrench. Hold the nut on the inside (near the spokes) with wrench as you tighten the screw with the screwdriver.
    • Tighten brake strap using screwdriver and 10mm socket wrench. Hold the nut on the inside (near the spokes) with wrench as you tighten the screw with the screwdriver.
  5. Center the wheel and pull back to tighten the chain
    • Center the wheel and pull back to tighten the chain
  6. With wheel pulled back, tighten the two axle nuts using the 15mm socket wrench. Tighten the non-drive side (side without the chain) first.
    • With wheel pulled back, tighten the two axle nuts using the 15mm socket wrench. Tighten the non-drive side (side without the chain) first.
    • Wheel will angle as you tighten. Keep it centered with your hand as you finish tightening both axle nuts.
Conclusão
Uma outra pessoa concluiu este guia.
Erin Heimburge
27 reputação
Autoria de 1 guia
Equipe
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 57
Todo: 5,608
