If the lightbulb of your Crown Range Hood Model AFG-AC/SS has burned out or has suddenly stopped working, use this guide to replace it.
Before beginning this repair, be sure that your stove is off and has cooled down so you don't get hurt.
Check to make sure the the range hood is off.
To turn the range hood off, press the highlighted button.
The range hood should not emit any light or make any noise.
Use the Phillips #00 to remove the single screw securing the lightbulb panel to the ceiling of the range.
Too prevent both of the items from falling, hold onto the screw and panel during removal.
Guide the new lightbulb to the middle of the lightbulb base.
Install the new lightbulb with a twisting motion to the right.
Ensure the lightbulb is tightly secured onto the lightbulb base but don't overtighten.
Incorporar este guia
Escolha um tamanho e copie o código abaixo para incorporar este guia como um pequeno widget no seu site / fórum.
Pré-Visualização
