Introdução
When everything is working as it should, the speaker produces nearly the same vibrations that the microphone originally recorded and encoded on a tape, CD or LP record.
O que você precisa
Using your Philips head screwdriver, remove the 10 outer black screws from the back of the device.
To reassemble, follow these instructions in reverse order. Then test by playing a tune. We suggest "Live at the Apollo" by James Brown.
Uma outra pessoa concluiu este guia.
Um comentário
I've got this but the music plays super quietly on the records I'm not able to turn up the sound would this be the solution?
